Code p0403
113,000 MILES • 2.5L • 3 CYL • TURBO • 4WD • MANUAL
SCRAGGY29
Had fault codes that say the EGR valve is faulty, so I replaced this with another one it wasn’t genuine so maybe that is faulty as well but same code? Any ideas? Could both EGR valves be faulty? I know these cheaper ones aren’t great? I can clear code but then after a while it’s back, wanted see if could try something else before ordering replacement EGR. thanks in advance.
Feb 25, 2021 at 12:04 AM
Good morning,
What is the code number?
Yes, some of the aftermarkets do not work as well as the OEM valves.
https://www.2carpros.com/articles/how-emission-control-systems-work
I attached a YouTube video from us about how the valve works and testing it.
https://www.youtube.com/watch?v=DqUCbbKdWf4
Feb 25, 2021 at 12:18 AM
SCRAGGY29
Thank you. so if a faulty valve would through the code out? Maybe it wasn’t good at all and replaced with a dud valve?
Feb 25, 2021 at 12:56 AM
Yes it is possible. I would get a new one from the dealer.
Feb 25, 2021 at 1:02 AM
