Camshaft position sensors Code P0365
102,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
RTSALDANA
Code P0365 Permanent DTC CMP Sensor (B) circuit no signal Trying to locate the sensors.
Aug 22, 2020 at 12:54 AM
I attached the info plus the testing for this code. Let us know if there is anything else you need. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks
Aug 22, 2020 at 1:02 AM
