Code p0322?
120,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
1.8L, only code is p0322.
Sep 4, 2022 at 7:40 AM
  • 110,248 POSTS
The code indicates there is no RPM signal from the engine speed sensor. Is the vehicle running? If so, what symptoms are you experiencing?
Since the code is specific, I attached diagnostics below for you. Take a look through them and let me know if you are comfortable performing them
Sep 4, 2022 at 2:06 PM
BHAMDOC1973
  • 2,007 POSTS
Yes, vehicle runs and drives but acts up while driving.
Sep 4, 2022 at 11:04 PM
BHAMDOC1973
  • 2,007 POSTS
Where is it located?
Sep 4, 2022 at 11:11 PM
  • 110,248 POSTS
The sensor is located behind the charge air tube. You need to remove it to gain access.
If you look below, I attached the directions for replacing it. I'm not suggesting it needs to be replaced, but the directions to access it are included.
Let me know how things turn out for you.
Sep 5, 2022 at 12:26 PM
