Code p0300, multiple misfires
160,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
CAPERDUE
The car was misfiring a little, every once in a while. But was running overall smoothly. So I replaced the spark plugs and wires. Now the car is misfiring pretty bad at idle and throwing code p0300. Double checked to make sure I had the firing order right and it was fine. And I'm getting fire to all cylinders, but when I pull the wire to check for spark it arcs up to 2 inches away... Do not know if that's normal. Checked for vacuum leaks but found none. Wondering what to do from here.
Oct 1, 2019 at 1:37 PM
  • 110,248 POSTS
Welcome to 2CarPros.
The spark you mentioned is excellent. If it jumps that far, you have a good coil. Now, many things can cause a random misfire. Is that the only code you get? Have you checked things such as fuel pressure? You mentioned checking for vacuum leaks. How was that done? Even a bad crankshaft position sensor or dirty fuel injectors can cause a misfire.
Let me know if there are other codes. Also, here are a couple link to help with checking fuel pressure and injectors:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Also, if you have a live data scanner, let me know what the fuel trims are and what the engine coolant temperature sensor indicated.
Oct 2, 2019 at 12:51 PM
