Check engine light on and code p0300
99,999 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DUSTY03
  • 6 POSTS
service engine light came on and now it is misfiring?
Aug 21, 2021 at 8:50 AM
  • 110,248 POSTS
A P0300 is a random misfire and isn't specific to any one cylinder. So, that simply means it could be the result of a few different things.
Since it is random and not specific, I doubt it is a spark plug or anything like that. What I would start with would be to simply check for engine vacuum leaks. Any unmetered air getting into the engine will cause issues.
Here is a link that shows how that is done:
If nothing is found, the next thing I would check is fuel pressure. Fuel pressure that is too high or low can cause a misfire as well. Here is a link that shows how that is done:
I attached the manufacturer's fuel pressure specifications below.
If you have a live data scan tool, let me know what the short-term fuel trims are as well as what the coolant temp sensor's signal is when the engine is cold and not started for the day.
See pic below.
Aug 21, 2021 at 2:20 PM
