Code P0139
104,300 MILES • AUTOMATIC
ANGELA ROSSI
  • 30 POSTS
I’ve had the downstream 02 sensor replaced twice and check engine light is back on. I thought the first sensor might have been faulty. Car is running good. I’m not noticing any issues otherwise when driving it. Any other issues that could be contributing to this and what do you recommend? Thanks.
Feb 29, 2020 at 1:19 AM
I suspect you have an air leak causing the o2 sensor reading to be off which is setting the code.
I attached the testing that we need to go through in order to determine the cause. Unfortunately there is no easy way to figure this out other than to run through the testing. I would not replace the sensor again as I think it is clear there is another issue. If you take a look at the second attachment it lists the possible causes which includes an air leak.
Let's run through this and see what we get. I am not sure if you are going to do this or have someone else. Either way, just let me know the results and we can walk through it together. Let me know if you have questions. Thanks
Feb 29, 2020 at 1:38 AM
ANGELA ROSSI
  • 30 POSTS
Thanks for getting back to me. I’m not sure how I would diagnose this myself, so I’m guessing I need to take it to a mechanic. Is this a lengthy test and would it be expensive in your opinion? I’m just wondering how much I would spend to repair this. I would love to keep this car as long as possible, but if things are going to go downhill then maybe it’s time for a new car. Not sure what to do. Thanks.
Feb 29, 2020 at 2:03 AM
I would definitely have it diagnosed. Normally that is only about $100.00 for them to tell you what the issue is. Then we will be able to better decide on what to do with it. In my experience these issues are not that expensive unless the part that is cracked or defective letting the air in (assuming that is the issue) is expensive.
So if it were me, I would take it to a reputable shop and have them provide an estimate on what it will take. Just make sure you tell them the sensor has been replaced so they don't jump to that conclusion.
Feb 29, 2020 at 6:42 AM
ANGELA ROSSI
  • 30 POSTS
So the mechanic I go to, who replaced the sensor in case the first one was faulty stated if the light came back on then most likely it is a larger issue such as the CAT, which I know is a lot of money. Does that make sense to you? Should I just ask him to check for air leaks? Sorry for all the questions. I appreciate your help.
Feb 29, 2020 at 6:50 AM
It could be the cat but I would think we would have other codes with this because we have the ability to monitor the efficiency of the converter.
I would make sure he is going through this test and not trying to diagnose this by his own testing. I suspect that is why he put the sensor on it because if you follow the testing through, it doesn't direct you to replace the sensor unless it was damaged. Clearly if this code keeps coming back then he is not fixing it. This is where it can get costly is when someone is replacing parts that are not actually diagnosed.
I am not suggesting this mechanic is doing this because all I have is our short conversation but I would think about getting a second opinion before spending a lot of money on it.
Feb 29, 2020 at 7:21 AM
ANGELA ROSSI
  • 30 POSTS
Is there a name for the testing you recommend? I’m trying to avoid the dealer, but do you think it would be better for this testing to be completed by them? They will definitely be more expensive. Also, the $100.00 that you said would that be just to have the test completed? I just want to make sure I’m using the correct terminology to have everything checked to avoid repeat trips to the mechanic. I really appreciate your help with this. Sorry for all the messages. Thanks.
Feb 29, 2020 at 7:51 AM
I understand. There is no name for the testing. It is just the diagnostic test for the P0139 code. I would ask that they follow the steps laid out in the diagnostic test for this code and tell you what they find.
The $100.00 that I mentioned is just a general cost for diagnostics in most areas. This is different for each shop in each part of the country. Basically it is an hour of time based on their door rate. So if they charge $100.00 per hour, they would charge someone $100.00 (or one hour) to figure out what is wrong. Then you will have a choice to make the repair or not. If you chose not to, then you just owe them the diagnosis charge. If you do, they will put that towards the cost of the repair. Basically, they charge for their time to figure it out or people would let them figure it out and then take it home and repair it themselves and the shop just lost out on the time it took to figure it out.
Please let me know if you need more info. That is why we are here. I will answer as many questions about this as you have. Thanks
Feb 29, 2020 at 8:00 AM
ANGELA ROSSI
  • 30 POSTS
Okay, so you are thinking it is a minor issue that needs repaired? In your opinion where would you draw the line in ending repairs and looking for another car? I know another CAT would not be worth it. I would say over the last few years I’ve put a little over $600.00 into the car not routine maintenance. The two main things are the 02 sensor and I had the radiator replaced. I think that was it. Again thanks for your help.
Feb 29, 2020 at 8:15 AM
At this point it is a simple cost comparison analysis. Meaning we never put more money into a vehicle then it is worth. So in your case, this vehicle could be worth anywhere from $2,000.00 to $5,000.00 depending on model and how it is equipped. That means we don't put more than that amount into in a given year. If you want to look at it on a two year basis or a 6 month basis that is up to you and your financial situation. Basically whatever you can afford without it breaking the bank. This does not include cost of maintenance. That is just a given that you are going to spend on any vehicle you own so this is only repairs.
From what I am seeing, you would be fine putting a cat in it if that is what it needs to fix it and keep it on the road. However, if something else happens that puts you over this then you will want to look at cutting your losses.
The idea behind this is let's say your vehicle is worth $2,000.00 and you make a $600.00 repair. If you sold the vehicle after making the repair you would leave with $1,400.00 net or if you sell the vehicle without doing the repair, you would probably get around $1,400.00
If you kept it and 6 months later it needed another $2,000.00 worth of work, then you would not do this repair because you would not be able to sell it for more than $2,000.00 and you now have $2,600.00 into it. In other words, doing these repairs does not add to the value so at some point it is better to sell it as is then repair it.
I don't think you are there yet.
Feb 29, 2020 at 9:38 AM
ANGELA ROSSI
  • 30 POSTS
In your opinion would you go to the dealer for this testing or just a mechanic? Obviously, the dealer would be more money, however I would think they would be more thorough, but maybe not. Thanks.
Feb 29, 2020 at 8:16 PM
That is always a hard question. Reason is, they are in general more expensive but for the most part you are going to get it taken care of quicker because they are use to working on these vehicles.
In your situation, I would feel good about going to a dealer but if you can ask around your circle of friends for a good repair shop then I am sure they would be able to follow this test as well.
However, the biggest benefit a dealer has is familiarity with the product and its issues. There is a lot to be said about that.
Mar 1, 2020 at 10:09 AM
ANGELA ROSSI
  • 30 POSTS
Thanks for getting back to me. I plan to take it to the dealer and discuss what we have talked about. I’ll be curious to your opinion if it is not an air leak. Thanks again and I will keep you updated.
Mar 1, 2020 at 11:32 AM
Yes. Please keep me in the loop with what they find and I will be happy to weigh in on what they find. Thanks
Mar 2, 2020 at 6:57 AM
ANGELA ROSSI
  • 30 POSTS
Hey Ken. So the mechanic I went to replaced the O2 sensor again in case the one replaced in December was faulty. My car is at the dealer now and they are saying it is the 02 downstream sensor that needs replaced. Of course the dealer is recommending a Kia brand sensor to be put in, which would be over $400.00. I asked the dealer if the sensor the mechanic used is not compatible with my car and he would not say that is the case. The dealer said maybe I want to go back and talk to the mechanic that put the sensor in. The dealer is not finding anything else wrong besides the 02 sensor being bad. I have no clue what to do. Thoughts?
Mar 12, 2020 at 1:28 AM
Clearly I would not want to replace the sensor again and it not work. So going back to the other mechanic doesn't seem wise because they are just going to replace it again with the same one.
I would do one of two things. First, ask the dealer to refund your money if they replace it and it doesn't work. Second, go back to the other mechanic only if he is willing to use the Kia sensor and credit the one you just put into it towards this one.
I find it hard to believe that the sensor that you put in is not compatible. At best it is just a cheap part and you are getting defective ones which is possible with these aftermarket parts. Did they say how they tested the vehicle? Did they write up their diagnostic steps on the repair order? I am just wondering if they tested the wiring. I would assume they did but clearly this is something we need to make sure or we will just keep putting sensors in it.
Mar 12, 2020 at 10:41 AM
ANGELA ROSSI
  • 30 POSTS
So apparently with Kia and Hyundai’s it is recommended to use OEM sensors versus aftermarket for best performance. I will look on the paperwork and see what all was tested and let you know at the dealer. The dealer did give me the sensor back that was in the car that was put in 3 weeks ago. Unfortunately, I cannot tell the brand of the sensor and it is not written on the paperwork from the mechanic who put it in. He did claim it was a name brand sensor. I originally purchased the sensor in December for $120.00. I was thinking about contacting the mechanic to see about getting a refund on the sensor. Another mechanic I spoke to online said that the mechanic’s supplier would take the sensor back and refund the mechanic. The issue I’m concerned about is after the mechanic replaced the sensor a second time he said if the CE light came back on then it is not the sensor and something else is causing the issue possibly the CAT. I would assume that the dealer checked everything and the sensor they put in is under warranty I know for a fact. In your opinion do you think the mechanic would refund me the cost of the sensor if I return it to him and advise that the dealer recommended the OEM sensor for the car? He might refute what the dealer said and still think it is another issue and therefore would not be willing to refund me. What do you think? Thanks.
Mar 12, 2020 at 7:43 PM
ANGELA ROSSI
  • 30 POSTS
So In looking at the receipt from the dealer the only thing that I see beside the sensor from being changed is a KCP2 Multi Point Safety Inspection. Does that mean anything. Verbally they assured me that there were no other issues. Thoughts? Thanks.
Mar 12, 2020 at 10:32 PM
The multi point inspection is just them looking over the vehicle to see if it needed any other work.
Knowing how dealers operate, I think they did the testing however I would be lying if I said I am 100% sure they are correct. I have seen too many times when they assume the wiring is ok. Due to having so many sensors in it, I would feel better if they had recorded all the testing.
If it were me this is what I would do. Call the dealer and talk to the service manager. Tell them that you have had X number of sensors installed and now you are saying that it needs a Kia sensor which is expensive and you are nervous what will happen if that doesn't fix it. I am sure the manager will understand and give you more info then "trust us, it needs the sensor."
Mar 13, 2020 at 9:36 AM
ANGELA ROSSI
  • 30 POSTS
I already had the dealer put an OEM sensor in. They did give me the aftermarket one back. I am debating to see if the mechanic who installed it would take it back and refund me for the cost of the sensor. Since the aftermarket was put in 3 weeks ago I would think it should be fine. My concern is the mechanic felt if the check engine light came back on it is something other than the sensor. If I tell the mechanic the dealer recommended an OEM sensor and I had that put in. The mechanic may feel that there is something else wrong with the car and may not want to take the sensor he put in back. What do you think?
Mar 13, 2020 at 11:46 AM
They do not keep the part. I would be surprised if they didn't give you the money back for at least the part. They are just going to return it from where ever they bought it from.
Can't hurt in asking.
Mar 13, 2020 at 11:52 AM
ANGELA ROSSI
  • 30 POSTS
I was told that the mechanic can probably send the part back to the supplier and get reimbursed. So I was hoping he would reimburse me.
Mar 13, 2020 at 12:24 PM
Yeah. If he is going to send it back then he should give you that money back because he doesn't pay for the parts. He checks charged by the supplier and then just transfers that cost to you. So he is just the middle man. That reimbursement is technically yours.
Mar 14, 2020 at 2:55 AM
