Code P0036?
2017 FORD EDGE
95,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
CARLOSMANDUJANO2001
Code P0036 this would be located under the car for the ho2 sensor, but I would like a diagram before I start digging under there.
Sep 2, 2023 at 12:14 PM
  • 110,241 POSTS
The code is specific to the heated oxygen sensor bank 1, sensor 2 (HO2S12). This code is set when the sensor does not warm up to the required temperature in a calibrated amount of time.
It could be caused by the sensor itself, a wiring issue, a damaged or corroded connector, a short, or an open circuit. Also, there is a technical service bulletin specific to the code which indicates the need to reprogram the PCM.
I attached the technical service bulletin below.
Sep 2, 2023 at 3:19 PM
