Code p0031 and P0037
109,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JOSE RODRIGUEZ2
  • 18 POSTS
i got these two codes out of my van, it has been like a four day now. how can i fix it ? can i still drive it at least three more days without worry of damage something? i read that i need to buy OEM parts, because aftermarket does not work well. The dealer is closed for weekend, but i need the van for transportation. help please!
Mar 18, 2017 at 7:06 AM
WRENCHTECH
  • 20,760 POSTS
Test all the fuses in the car using a test light with the key on.
Mar 18, 2017 at 7:55 AM
STEVE W.
  • 15,370 POSTS
P0031= Oxygen Sensor Heater Control Circuit Low Bank 1 Sensor 1
P0037= Oxygen Sensor Heater Control Circuit Low Bank 1 Sensor 2
Check the fuses and check the wiring harness that leads to the sensors. These codes can be caused by power failure to the heater circuit or an open circuit to ground.
Both of those share the same ground wire and are spliced partway up the harness before they reach connector C111. Check for continuity between the grounds of the sensors and the chassis. No ground = broken wire or bad connector.
Got the Versa figured out yet?
Mar 20, 2017 at 12:30 PM
JOSE RODRIGUEZ2
  • 18 POSTS
Change both sensor but light still on, use a small scanner to erase codes but still coming back, can i damage something by driving it like that?
Mar 26, 2017 at 9:21 AM
WRENCHTECH
  • 20,760 POSTS
Did you test the fuses as I suggested in the first response?
You got 2 responses and neither of them suggested replacing any sensors.
Mar 26, 2017 at 9:23 AM
JOSE RODRIGUEZ2
  • 18 POSTS
I check the ones close to the battery, all fine Where are connector C111 located? ?? can i drive the car on freeway? need to go out of town like 500 ml round trip
Mar 26, 2017 at 3:20 PM
STEVE W.
  • 15,370 POSTS
C111 is in the harness coming from the O2 sensors under the vehicle. Not near the battery. The grounds both break out and are attached at ground point G100 which is on the transmission.
Mar 26, 2017 at 8:29 PM
JOSE RODRIGUEZ2
  • 18 POSTS
check the grounds, fuses, everything's fine, including disconnecting the ground from the battery what else?
Apr 5, 2017 at 4:56 PM
  • 55,560 POSTS
It sounds like its time to check some wiring, here is a wiring diagram and a guide so you can do some testing.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 8, 2017 at 4:50 AM
