Code P0016
104,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
HECTORHB29
Car has code P0016, both intake and exhaust camshaft sensors have been replaced. Car feels like it wants to start but it doesn't. I've also replaced timing belt with new tensioner and idler. Compression per cylinder is 135 psi. There's spark from coil pack when cranking and fuel pressure is about 60 psi. I would like to check signal from camshaft sensors at ECM but don't have access to wiring diagrams. Any help you can provide me with I'll appreciate it. Thank you.
Mar 9, 2020 at 11:00 AM
  • 110,251 POSTS
I attached the entire power-train management wiring schematics. I had to break each pic in two to make them readable. I did overlap the to make it easy to follow. They are in order.
Let me know if this helps.
Mar 9, 2020 at 1:44 PM
HECTORHB29
Thank you for your help. Vehicle had a bad intake camshaft solenoid.
Mar 31, 2020 at 2:53 AM
  • 110,251 POSTS
Happy to hear you found the problem. Let us know if you have questions in the future.
Mar 31, 2020 at 4:13 AM
