Codes P0013 and P0014
137,275 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
KAITPERRY24
I've tested both the intake solenoid and the exhaust solenoid for the camshaft but i'm not entirely sure what the OHM's are supposed to read for my particular make and model.
I have a replacement for the camshaft sensor bank 1. But I was just informed that there are two camshaft sensors. I guess I am unsure if I should change them both or just one at a time? And which one is which?
Oct 1, 2020 at 8:43 AM
I am attaching the testing for these codes. Basically it is the solenoid that is most likely the issue and not the sensor. The actuator resistance needs to be between 8-12 ohms. Run through the testing and let me know what questions you have. Thanks
Oct 1, 2020 at 10:03 AM
