CODE ISSUE
200,000 MILES
JEAN M
I took it to be inspected, they said that it was throwing a code, they did not state on the paper work what the code meant, how do I find out what the code means ?
Jun 28, 2016 at 6:29 AM
JIS001
  • 3,412 POSTS
What code you have? Is the check engine light on?
Jun 28, 2016 at 7:13 AM
JEAN M
no the check engine light was not on, they said that the code might be for the converter, but they were not sure, but it would not pass inspection.
Jun 28, 2016 at 7:26 AM
HMAC300
  • 48,601 POSTS
go to an auto parts they can probably get the code and they do it with no charge.
Jun 28, 2016 at 8:36 AM
CARADIODOC
  • 34,414 POSTS
Any diagnostic fault code that refers to something that could adversely affect emissions will turn on the check engine light, but the severity of that code affects how the light acts. If the problem is intermittent, the check engine light might go off while driving when the problem stops acting up. If it is more severe, the light will be on any time you are driving, even if the problem stops acting up.
When the check engine light was never on, the problem that was detected is not related to increased emissions. That includes the catalytic converter. Its job is to clean up the exhaust gas, so any problem with the converter will result in increased emissions and will turn the light on.
The people at most auto parts stores will read fault codes for you for free, but remember they are in the business of selling parts. It is important to understand that fault codes never say to replace parts or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a part is referenced in a fault code, that part is actually the cause of the code about half of the time. First you have to check for cut and grounded wires, stretched or corroded connector terminals, and things like that.
When you have the codes read, record the numbers. We have a list of descriptions. Those descriptions from code readers, when they are supplied, can be confusing at times.
Jun 28, 2016 at 8:53 AM
JEAN M
thanks.
Jun 28, 2016 at 8:57 AM
  • 55,732 POSTS
Its best if you can take matters into your own hands and get a code reader from amazon for about 50.00 bucks and follow this guide.
Let us know what you find.
Best, Ken
Jul 6, 2016 at 1:20 PM
