code indicates PO455
144 MILES
JOHNNYCAM
I was at a gas station filling up pulled out and computer indicated loose gas cap I tightened the cap and soon after the service engine light came on and has not went off after a weeks driving I had the car tested at a jiffy lube on the computer and the code indicates PO455 can you tell me what part to replace 1st thanks
Apr 15, 2013 at 2:15 PM
455 is a large leak in the system.
you need to have a smoke machine, scan tool and voltmeter to track down the failed part
Apr 16, 2013 at 12:50 PM
