Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jaguar
XJS
Trouble Codes
P Codes (Powertrain)
Code ff24
1994 JAGUAR XJS
109,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANUSXJS
MEMBER
1 POST
Car runs beautifully but check engine code ff24 appears. What does it mean and what repairs are needed?
Jun 20, 2022 at 11:47 AM
Experienced Mechanic
By chance, did you have a drained battery or anything that required the battery to be disconnected?
If you have, try this. Disconnect the battery then turn the high beams on for 5 minutes to drain the little computer chip battery.
Reconnect the battery and the light "should" be gone.
Jun 21, 2022 at 9:04 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
