Code ff24
109,000 MILES • 4 CYL • 2WD • AUTOMATIC
JANUSXJS
Car runs beautifully but check engine code ff24 appears. What does it mean and what repairs are needed?
Jun 20, 2022 at 11:47 AM
  • 110,248 POSTS
By chance, did you have a drained battery or anything that required the battery to be disconnected?
If you have, try this. Disconnect the battery then turn the high beams on for 5 minutes to drain the little computer chip battery.
Reconnect the battery and the light "should" be gone.
Jun 21, 2022 at 9:04 AM
