Codes
130 MILES • 2.4L • 4 CYL • AUTOMATIC
AERON
I have codes; p0102, p0113, p011, p0102 and p0113 caused by p0011?
Aug 21, 2016 at 3:17 AM
HMAC300
  • 48,601 POSTS
there is no code 111 there is 112 the 102 code may effect the other two which is the air intake temperature sensor. cleaning the MAF is a waste of time as they are self cleaning anyhow. You must have talked to the clown behind the counter at an auto parts. they do not know much about fixing cars especially sensors. i am sending pictures on how to check both of these codes. although you may not be able to check hertz on a MAF sensor. try the 102 code first which is MAF also check all stuff in third picture like vacuum leak , broken or hole in duct work leading to engine from MAF.
Aug 21, 2016 at 5:53 AM
AERON
I was asking about code (P0011) which is low voltage on camshaft actuator sensor and its affect on codes P0102 and P0113.
Aug 21, 2016 at 6:39 AM
AERON
I was asking about code( P0011) which is low voltage on cam actu ator sensor and it's affect on codes P0102&P0113
Aug 21, 2016 at 6:41 AM
HMAC300
  • 48,601 POSTS
sorry I misread it . no it will not effect the other two codes. if you pull actuator out check for a blocked screen or debris in front of it not getting oil pressure or a missing screen, etc.
Aug 21, 2016 at 8:21 AM
AERON
Thank you for the second opinion this is what I thought at first.
Aug 21, 2016 at 9:29 AM
RENEE L
  • 1,260 POSTS
Please let us know what you find so it can help others
Aug 30, 2016 at 2:38 AM
