My daughter was driving somewhere, called to tell me check engine light is on. Asked her if any symptoms she said no. I told her have her brother scan it when she gets back. He did and it was cd9010, he deleted it twice and it still came back. I took it while monitoring coolant temp all readings like it should. Fhecked coolant and ir was a tiny bit lower than it should so topped it off. Chexked the ground in the bulk harness on engine and its right. Checked for leaks none. Removed water pump connector cleaned it out. Fans come on like they should. I deleted it and it didnt come back but i have mot driven it a distance yet. This is a LIn code. Usually if it is the water pump it would be at higher miles and would give different codes. Xar does not overheat.
Nov 1, 2026 at 7:08 AM
