code c1253
100,000 MILES • V8 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
only code under ABS module, TRACTION, ABS AND BRAKE LIGHTS ARE ON.
Sep 22, 2025 at 5:33 AM
  • 55,561 POSTS
It looks like the ABS module needs to be replaced or maybe the ABS motor 2 relay we can try first.
C1253 - Hydraulic System Malfunction (Pump Motor Relay)
This is an ABS / Brake Actuator related fault. On your LS 460, the brake actuator assembly has an integrated pump motor and relay.
You might able to change out the relay. Here is the location which is on the left side of the engine compartment. Check out the images (below). Let us know what you find.
Sep 22, 2025 at 10:43 AM
BHAMDOC1973
  • 2,007 POSTS
Thanks. Are you sure it's not the relay in the bigger fuse box next to it? some people say they replaced the bigger fuse box which has the built in relay within it
Sep 22, 2025 at 11:24 PM
  • 55,561 POSTS
Here it shows the location of the relay. Check out the images (below).
Sep 23, 2025 at 1:18 AM
