Code c0226?
2002 GMC SIERRA
250,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
WILL11177
Truck starts and runs but in 3-5 minutes jumps out of gear to neutral. When I shut it off and restart it in 30 seconds to a min, it will drive again but within a couple of minutes it will get out of gear again. And switching to lower gears manually or 4x4 doesn't change anything. I changed the wheel speed sensor, but it remains the same. Thanks for any input.
Feb 15, 2025 at 7:17 AM
  • 110,244 POSTS
I need you to check if the wheel speed sensors are producing a voltage signal. Although the sensors are new, there could be an issue with a tone ring and the sensor isn't producing a signal.
Here is a link that provides directions for testing. You can do it this way or if you have a live data scanner, check to see if the sensors are all signaling the same.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Note, the link shows how to test the sensor and also test to confirm it is putting out voltage.
Feb 16, 2025 at 12:50 PM
