Code power assist failure
2007 FORD FOCUS
80,500 MILES • 1.8L • 4 CYL • 2WD
SHAMIE
Had new steering pump fitted, but error code"power assist failure" still on dashboard display. How do I delete/reset myself without help from main dealer?
Aug 6, 2016 at 1:47 AM
HMAC300
  • 48,601 POSTS
a mechanic has to use his scanner to remove those auto parts cannot or a dealer can.
Aug 6, 2016 at 3:54 AM
SHAMIE
Cannot quite understand this message. Are you saying that only a mechanic at the main dealer can remove this message from the display? Jim
Aug 7, 2016 at 3:18 AM
HMAC300
  • 48,601 POSTS
a mechanic at a local garage or dealer is what is meant to be said. it does not need to go to a dealer, just tell him what you have done, but if it comes back after it was erased the pump was not the problem.
Aug 7, 2016 at 4:47 AM
