tire monitor system light came on
2008 CHEVROLET SILVERADO
155,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
LUISG5210
  • 9 POSTS
The tire monitor system light came on after I had some new tires installed on it what could be the cause of that? I have a code c0267 abs code? Anyone familiar with that and how to fix it?
Oct 12, 2016 at 11:30 PM
AL514
  • 5,639 POSTS
This code is a Traction Control disabled code, my guess, go with the obvious. They may have put on a tire size that the ECM for ABS and Traction control does not recognize. The ride Height of the vehicle may not be correct or another symptom its seeing. The tire size and pressure is on a tag on the inside of the driver side door
Oct 13, 2016 at 2:48 AM
LUISG5210
  • 9 POSTS
Okay, yes I understand, but I had off road tires before and did not have the problem. Now that a put a brand new set that code came up? Does it need to be rest or relearn to the new off road tire height and PSI?
Oct 13, 2016 at 3:34 AM
AL514
  • 5,639 POSTS
a reset is possible, but are you sure you have the right tire size on for the vehicle, another possibility is one of the ABS sensors or wires have been damaged during the tire change over. You can do a visual inspection of the ABS sensors and their wires and just see if u notice any damage. Something has changed to set that code. You may just try clearing the code and see if it comes back.
Oct 13, 2016 at 11:35 PM
AL514
  • 5,639 POSTS
i have been doing a lot of reading about this code, its a lacking communication or fault in another module to the EBCM. I would just erase it for now go for a good road test and see what comes back for codes if any.
Oct 13, 2016 at 11:39 PM
