Code 4E89
2008 BMW 735
180,966 MILES • 3.5L • V8 • RWD • AUTOMATIC
MB-POWER
  • 80 POSTS
Hi all ,
when drive the car the gear changed to (N) automatically , after scanned we found code of (4E89), solenoid valves one and two has been replaced with used one. but the problem still same. oil level is okay .
can you help please?
Thanks
Jun 21, 2017 at 11:02 PM
  • 55,433 POSTS
This codes comes up for one of two things, first the solenoid goes bad which you already replace the second is the seal for the clutch pack that changes the gears goes out not holding pressure which causes the clutches to slip. How was the condition of the fluid, burnt?
Please let us know
Cheers, Ken
Jun 24, 2017 at 5:39 AM
MB-POWER
  • 80 POSTS
Hi ,
fluid has been changed & the old fluid was normal , valve body has been changed with used one . the seal for the clutch pack has been changed also !!!
your advice please.
thanks
Jun 27, 2017 at 4:55 PM
MB-POWER
  • 80 POSTS
scanned again but the fault code now is ( A3AA) !!!
Jun 27, 2017 at 10:45 PM
  • 55,433 POSTS
Clear the codes again and drive it for a bit to see what happens. Try a capacitor discharge by removing the negative battery cable from the battery and touching it to the positive terminal. Leave it there for 10 minutes.
Jun 28, 2017 at 4:17 AM
MB-POWER
  • 80 POSTS
done , car has been tested & every thing is okay now.
thank you very much.
Regards
Jun 28, 2017 at 7:48 PM
  • 55,433 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jun 29, 2017 at 3:49 AM
