I would start by replacing the ignition coil that is usually what that code means. I would check the module anyway.
Cheers, Ken
Oct 12, 2017 at 4:36 AM
KZUELICH
MEMBER
Okay I will change the coil. got one here at home on Monday when i am off .
Oct 12, 2017 at 6:33 AM
KZUELICH
MEMBER
i think i found the problem the wires from the distributor to the coil are not even connected will replace on payday.
Oct 12, 2017 at 7:16 AM
✓Experienced Mechanic
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Oct 13, 2017 at 3:00 AM
KZUELICH
MEMBER
ok made coil wires. still ran like crap. put a new coil that i had still runs like crap anything else i need to test.
Oct 17, 2017 at 7:03 AM
Please pull the spark plugs and check there condition. If you can snap a picture of them and upload it here. If they are okay I would suspect an ignition module.
