code 42
2,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
KZUELICH
  • 13 POSTS
i am getting a code 42. i replaced the distributor, knock sensor, and ECM. is there away to test the ESC module?
Oct 11, 2017 at 6:40 AM
  • 55,721 POSTS
You can take it to an auto parts store they have a special machine that can check it for you.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
I would start by replacing the ignition coil that is usually what that code means. I would check the module anyway.
Cheers, Ken
Oct 12, 2017 at 4:36 AM
KZUELICH
  • 13 POSTS
Okay I will change the coil. got one here at home on Monday when i am off .
Oct 12, 2017 at 6:33 AM
KZUELICH
  • 13 POSTS
i think i found the problem the wires from the distributor to the coil are not even connected will replace on payday.
Oct 12, 2017 at 7:16 AM
  • 55,721 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Oct 13, 2017 at 3:00 AM
KZUELICH
  • 13 POSTS
ok made coil wires. still ran like crap. put a new coil that i had still runs like crap anything else i need to test.
Oct 17, 2017 at 7:03 AM
  • 55,721 POSTS
Please pull the spark plugs and check there condition. If you can snap a picture of them and upload it here. If they are okay I would suspect an ignition module.
Oct 17, 2017 at 10:45 AM
KZUELICH
  • 13 POSTS
ok will do
Oct 17, 2017 at 11:06 PM
