Code p0304 cylinder misfire
53,000 MILES • 2.0L • 4 CYL
GARYMCC
  • 9 POSTS
I have had all spark plugs and coil packs done and the engine light keeps coming on. anything else it could be? thanks
Feb 24, 2020 at 3:44 AM
  • 110,246 POSTS
If you still have a misfire, it could be a few things. Since it is limited to cylinder 4, that needs to be our focus.
First, I need to know the following. Do you have a live data scanner? Have you checked fuel pressure? Have you checked for engine vacuum leaks? Are there any exhaust leaks?
If the above checks were done and passed, I need to know about the scanner. I will need the short term fuel trims. If fuel trims are good, then we will have to perform a compression test. Low compression can cause a misfire. A partially plugged catalytic converter can also cause a loss of power and misfire.
I have to be honest. This model isn't offered in the US, so my technical information is very limited. However, I'll do my best to help
Here are links for the above tests:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know. Also, let me know if you can feel the misfire when driving.
Feb 24, 2020 at 9:25 AM
GARYMCC
  • 9 POSTS
Hi, I have a obd2 scanner. I haven't done any tests not that good with cars. when you open the oil cap there is a bit of pressure. is that something to worry about or is that because i am getting the misfire? thanks
Feb 24, 2020 at 5:30 PM
GARYMCC
  • 9 POSTS
You can feel it when you drive. thanks
Feb 24, 2020 at 5:31 PM
GARYMCC
  • 9 POSTS
Could it be the fuel injectors or the catalytic converter, oxygen sensor? people just keep saying could be this could be that.
Feb 25, 2020 at 4:10 AM
  • 110,246 POSTS
A small amount of pressure isn't out of the ordinary. Since you have a live data scanner, can you let me know what the fuel trims are?
And yes it could be any of those. If you can get the fuel trims, it will help me. As far as a an injector, yes. Here is a link that shows how to test one:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Feb 25, 2020 at 10:46 AM
GARYMCC
  • 9 POSTS
Is that what you wanted to see?
Feb 26, 2020 at 4:13 AM
  • 110,246 POSTS
Yes, that's what I needed. The STFT of 99 indicates the computer is adding fuel. This happens when there isn't enough fuel to the engine and too much air. Usually, this is the result of a vacuum leak, low fuel pressure, damaged regulator, bad O2 sensor, which yours looks okay, a cracked exhaust manifold, dirty or damaged fuel injector and so on.
With all of that, have you checked fuel pressure? Also, are there any exhaust leaks?
Feb 26, 2020 at 9:51 AM
GARYMCC
  • 9 POSTS
Okay, thanks for getting back to me. won't be able to look at it until Saturday now.
Feb 26, 2020 at 8:50 PM
GARYMCC
  • 9 POSTS
How would you go about finding out what it is out of all them? what would I be best starting with? thanks for your help .
Feb 27, 2020 at 5:10 AM
  • 110,246 POSTS
I would start by checking for vacuum leaks. They are most common. Then I would check fuel pressure and the regulator. Here are a couple links to get you started:
Start with that and let me know the results. And try to relax a little over the weekend. Like you, it always seems my cars know when it's the weekend. That's when they break. LOL
Feb 27, 2020 at 9:46 AM
GARYMCC
  • 9 POSTS
Hi, I am going to do them test tomorrow. is it easy to do a compression test and test the fuel injectors? I have bought a compression test kit. any help would be great. thanks
Mar 3, 2020 at 7:34 AM
  • 110,246 POSTS
The link above shows in general how to perform a fuel pressure test As far as the compression test, here is a link showing how in general it too is done:
I don't have the specifics on this model, but the links should help. You are welcome to come back anytime if you have questions.
Let me know if I can help. And no, it isn't hard. A bit time consuming.
Mar 3, 2020 at 11:14 AM
