Code 171
2012 CHEVROLET CRUZE
106,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
JLR2671
Check engine light have 171 code. Lean bank 1 changed mass air flow sensor. Which did help but the light came back on still has some hesitation.
Oct 8, 2018 at 7:28 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
A lean mixture can be caused by a couple things. First, an engine vacuum leak can cause it. Also, low fuel pressure. With that being said, I need you to check a couple things. First, here is a link that discuss how to check for a vacuum leak. You will need a gauge, but most parts stores will lend you one.
Here is a link for checking fuel pump pressure:
Here are the pressure specs specific to your vehicle:
FUEL PRESSURE
Fuel Pressure (Key ON, Engine OFF) .................... 250-450 kPa (36-65 PSI)
Should not decrease greater than .................... 34 kPa (5 PSI) in 1 min
Oct 8, 2018 at 7:36 PM
