Will not start, codes 16705 and 17521
157,486 MILES • 2.0L • 4 CYL • 2WD • MANUAL
WOODROWE83
The 17521 code is s1/b1 lean.
The 16705 code is engine speed sensor faulty or no signal.
I have replaced both oxygen sensors and replaced the engine speed sensor and reset my ECU and the car still wont start and throws the same codes after a few times trying to start it. I have even tried disconnecting the battery, and putting my camshaft back to TDC before reconnecting my battery, and still nothing. Please help!
May 17, 2019 at 3:13 AM
  • 110,248 POSTS
Welcome to 2carPros.
Are you getting fuel and spark to the engine? A lean code can often times correlate with a vacuum leak or low fuel pressure.
Take a look through this link:
Next, check and confirm spark and fuel to the engine. Here are a couple links showing how it is done:
__________________________________________
Here are the directions specific to checking pressure on your vehicle. You will need a scanner to do this and few other things. The attached pics correlate with the directions.
WITH GENERIC SCAN TOOL
Fuel Pressure Regulator And Residual Pressure, Checking
Function
The fuel pressure regulator controls the fuel pressure as a function of the Manifold Absolute Pressure (MAP).
The specified value for this test is dependent on the working pressure of the Fuel Pump (FP). This is about 3.0 bar positive pressure
Recommended special tools and equipment
pic 1
- V.A.G 1318 pressure gauge
- VAG1318/10 adapter
- VAG1318/11 adapter
- VAG1318/16 hose adapter
- VAS5024 assembly tool for spring-type clamps
Test requirements
- Parking brake must be engaged or else daylight driving lights will be switched on.
- For vehicles with automatic transmission, selector lever must be in position -P- or -N-.
- Delivery quantity of Fuel Pump (FP) OK, check, Fuel Pump (FP), checking. See: Fuel Pump > Component Tests and General Diagnostics
Test sequence
CAUTION: Fuel system is under pressure. Before opening system, place rags around the connection point. Then release pressure by carefully loosening connection.
pic 2
- Disconnect fuel supply line -1- (black) from fuel distributor and catch escaping fuel using a rag.
pic 3
- Connect pressure gauge to adapter (VAG1318/10) at supply hose and to adapter (VAG1318/11) and hose adapter (VAG1318/16) at supply line.
- Open shut-off valve of pressure gauge. The lever points in the direction of flow (arrow).
- Start engine and let run at idle.
- Measure fuel pressure. Specified value: about 3.5 bar positive pressure.
pic 4
- Disconnect vacuum hose -1- from connecting piece -2-. Fuel pressure should rise to about 3.0 bar positive pressure rise.
NOTE: If fuel should escape at the vacuum connection of the pressure regulator, replace fuel pressure regulator, item 1.
- Switch ignition off.
- Now check for proper seal and residual pressure. Observe pressure drop on pressure gauge for this. After 10 minutes at least 2.0 bar positive pressure should still be present.
If residual pressure falls below 2 bar positive pressure:
pic 5
- Wait until pressure has risen, and then switch off ignition. Simultaneously close shut-off valve of pressure gauge (lever perpendicular to direction of flow -arrow-).
- Observe pressure drop on pressure gauge.
If pressure does not drop:
- Test check-valve of Fuel Pump (FP), Fuel Pump (FP), checking. See: Fuel Pump > Component Tests and General Diagnostics
If pressure does drop again:
- Open stop valve of pressure gauge (lever in direction of flow -arrow-).
- Wait until pressure has risen, and then switch off ignition. Simultaneously pinch return hose tightly together.
- Replace fuel pressure regulator, item 1.
- Erase DTC memory of Engine Control Module (ECM), Diagnostic mode 4: Reset/erase diagnostic data. See: Computers and Control Systems > Scan Tool Testing and Procedures > Diagnostic Mode 4: Reset/Erase Diagnostic Data
- Generate readiness code. See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes
- Check whether line connections, O-rings in fuel rail, and fuel injectors are properly sealed.
- Check whether pressure gauge is properly sealed.
NOTE: Before removing pressure gauge, put cleaning rags back around line connection which is to be disconnected.
May 18, 2019 at 3:58 PM
WOODROWE83
The 16705 code in my car prevents spark to the engine due to it not knowing the engine's RPM speed. I can't start it to check fuel pressure, and I replaced the entire smog system. No vacuum leaks as far as I know. The 17521 code went away after I replaced the O2 sensors and only came back on after I have been cranking it. I know that there's air in the fuel line due to me having to disconnect it to rwplace the camshaft sensor. I'm at a total loss. On the crankshaft position sensor: in the wiring between the crankshaft sensor harness and the ECU supposed to have continuity between all three terminals?
May 18, 2019 at 10:54 PM
  • 110,248 POSTS
Welcome back:
They should show continuity.
P0321 16705 Ignition/Distributor Engine Speed Input Circuit Range/Performance
With that code, the ignition isn't receiving a signal from the crankshaft position sensor (Engine speed sensor). All wire should have continuity. Is there one that doesn't?
I attached three pictures. The first shows the sensor and wiring to it. The second indicates a splice in the wiring (which could be the issue). And the third shows where the three wires connect (pins) on the ECM.
Take a look to see if there is an issue at the splice and if all wires show continuity between the sensor and ECM.
Let me know what you find.
May 19, 2019 at 10:58 AM
