Flashing Check Engine Light with Code P1326?
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BOSTONBOATSWAIN
  • 45 POSTS
Driving on expressway, I felt a hiccup and suddenly the car won't go over 60 MPH and the check light flashing.
I had an exhaust manifold put in 2 days prior, not sure if something from the shop when they installed.
Also, a new Cat was put on 4-5 months ago.
What is the easiest/fastest/cheapest fix for this?
Any help is greatly appreciated.
Thanks,
Diane
Dec 18, 2023 at 10:09 PM
  • 55,628 POSTS
Hi Diane,
This could be a defective catalytic converter or an engine misfire, but we need to run the codes to see what they are then we can help fix the problem. here is a guide to help us get started:
Please go over this guide and get back to us.
Dec 19, 2023 at 5:12 AM
BOSTONBOATSWAIN
  • 45 POSTS
Code is P1326. Never had prob before I had an exhaust manifold installed. Next day I drove it, I got a code. Cleared code but it came back few days later. Also, I believe the update they did to my car was several months ago.
Dec 19, 2023 at 8:03 AM
BOSTONBOATSWAIN
  • 45 POSTS
Also, had a new catalytic converter installed couple months ago.
Dec 19, 2023 at 7:45 PM
  • 55,628 POSTS
The code P1326 in a 2014 Kia Soul typically indicates an issue related to the "Knock Control System Performance." So, if the engine has an internal problem, it can be making noise which triggers the knock sensor code, can you please upload a shirt video of the engine running so I can hear it? You can upload it here with your response.
Dec 21, 2023 at 5:08 AM
BOSTONBOATSWAIN
  • 45 POSTS
Ten tries but I finally got vid loaded.
(Not your system-my crappy phone).
Seeing a lot of people getting this.
Jan 4, 2024 at 12:52 PM
  • 55,628 POSTS
Yep, that is a noisy engine, it sounds like the timing chain guide has broken and the timing chain has jumped, but to be sure let's do a compression test which will help tell us what is going on.
This guide will help us:
If the compression is low across the board this is the problem. Please go over this guide and get back to us.
Jan 5, 2024 at 1:54 AM
