code
54,000 MILES
FWADE123
my wife was driving back from her parents house this past mothers day when her check engine light came the car seemed to be running fine and made it home with no problems the next day i took it to oriellys to get the codes read for the check engine light it came up as p1175 but there computer had no history of this code so my question is this a sever condition and what needs to be done to correct this problem thank you for your help
May 13, 2013 at 6:51 AM
DTC P1174 or P1175
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P1174: Fuel Trim Cylinder Balance Bank 1.
DTC P1175: Fuel Trim Cylinder Balance Bank 2.
Circuit/System Description
The Fuel Trim Cylinder Balance diagnostic detects a rich or lean cylinder to cylinder air/fuel ratio imbalance in each bank. The diagnostic monitors the pre-catalyst heated oxygen sensor (HO2S) signal's frequency and amplitude characteristics by calculating an accumulated voltage over a predetermined sample period. An imbalance is indicated when multiple samples of the accumulated voltage are consistently higher than the desired value.
Conditions for Running the DTC
DTCs P0030, P0036, P0050, P0053, P0059, P0101, P0102, P0103, P0106, P0107, P0108, P0117, P0118, P0128, P0131, P0132, P0133, P0134, P0135, P0151, P0152, P0153, P0154, P0155, P0201-P0206, P0300, P0301-P0306, P0411, P0412, P0418, P0442, P0443, P0446, P0449, P0452, P0453, P0454, P0455, P0496, P1133, P1153, P1516, P2101, P2119, P2120, P2125, P2135, P2138, P2176, P2431, P2432, P2433, P2440, P2A00, P2A03 are not set.
The device control is not active.
The intrusive diagnostics are not active.
The engine overspeed protection is not active.
The power take-off (PTO) is not active.
The traction control is not active.
The fuel control is in air-fuel Closed Loop.
The system voltage is more than 10 volts, or less than 18 volts.
The engine run time is greater than 100 seconds.
The engine coolant temperature (ECT) is greater than -20°C (-4°F).
The engine speed is greater than 425 RPM, but less than 6,000 RPM.
The mass air flow is greater than 25 g/s, but less than 510 g/s.
Conditions for Setting the DTC
Multiple samples of the pre-catalyst HO2S accumulated voltage are consistently greater than the desired value.
Action Taken When the DTC Sets
DTCs P1174 and P1175 are Type B DTCs.
Conditions for Clearing the MIL/DTC
Diagnostic Aids
The fuel trim cylinder balance diagnostic is very sensitive to heated oxygen sensor (HO2S) design. A non-OE sensor or an incorrect part number may set a false DTC.
Monitoring the misfire current counters, or misfire graph, may help to isolate the cylinder that is causing the condition.
Circuit/System Testing
Read and record the Freeze Frame/Failure Records data taking note of the speed and load at which the DTC set.
Diagnose any other DTCs that are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle.
With the engine idling and the transmission in the Park or Neutral position, observe the manifold absolute pressure (MAP) sensor parameter. The MAP sensor parameter should be between 19-42 kPa.
If the MAP sensor parameter is not between 19-42 kPa, refer to DTC P0106 or DTC P0107 or P0108.
Inspect the air induction system for modified, damaged, leaking, or restricted components.
Inspect the crankcase ventilation system for improper operation.
Inspect the vacuum hoses for splits, kinks, and improper connections.
Inspect for vacuum leaks at the intake manifold, the throttle body, and the injector O-rings.
Test for a restricted, damaged, leaking, or modified exhaust system from the catalytic converter forward. Refer to Symptoms - Engine Exhaust.
Test the fuel injectors for improper operation. Refer to Fuel Injector Diagnosis.
Test for fuel contamination. Refer to Alcohol/Contaminants-in-Fuel Diagnosis.
Test for fuel composition error, FlexFuel/E85, only. Refer to Fuel Composition Diagnosis.
Test for excessive fuel in the crankcase due to leaking injectors.
Test the ignition system for improper operation. Refer to Electronic Ignition System Diagnosis.
Test the engine for any mechanical conditions such as sticking valves, lifters, etc., which could alter the flow into the combustion chamber. Refer to Symptoms - Engine Mechanical.
May 13, 2013 at 11:10 AM
