Clutch hard to push and will not shift into gear or start
221,580 MILES • 2.3L • 4 CYL • 2WD
HARTWELL
it worked until I shut it off.
Aug 26, 2020 at 9:57 AM
Have you replaced the clutch or any components recently? If not, it sounds like the clutch has just failed and is in need of replacement.
Here is a guide that talks about different issues causes by a failed clutch:
https://www.2carpros.com/articles/clutch-symptoms
Let us know if there are any other things that have happened recently as far as repairs. If not then I would just go ahead and replace the clutch and related components such as flywheel, bearings, and slave cylinder. Thanks
Aug 26, 2020 at 10:39 AM
