clutch/transmission
180,000 MILES • 0.5L • 4 CYL • 2WD • MANUAL
LAURA BETH
I can shift into gear without pushing in the clutch, sounds like it goes into gear when I do press the gas but wont move forward or backwards. Engine revs up when I press on the gas. This happened after I tried to pop start it twice then when I tried the third time there was a loud pop and it stopped moving.
Jun 26, 2016 at 8:52 PM
HMAC300
  • 48,601 POSTS
sounds like a clutch problem like the disc is bad.
Jun 27, 2016 at 12:05 AM
  • 55,808 POSTS
Hi LAURA,
Yep the clutch disc is bad, here is a guide on what you are in for for to replace it, this is a rear wheel drive car but the process is very similar.
https://www.2carpros.com/articles/how-to-replace-a-clutch
please let us know what happens
Best, Ken Lavacot
Jun 27, 2016 at 1:42 AM
