Clutch to the floor
230,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
GABBYGILBO
  • 55 POSTS
I spoken with you guys before I had it replaced the master cylinder at the slave cylinder and a clutch kit for $1,800.00 in 2019 if you get days ago I believe it to be December 22nd 2020 my clutch goes to the floor.
after my clutch was repaired I've sent you multiple text and pictures regarding the job that they did and the questions I had about it.
I'm unsure if you receive that documentation as of now, but I want to know within a year why would my clutch go bad.
There was no indication whatsoever. no smell no noise no feeling nothing.
I'm asking you where do I go from here? Please help me
Dec 27, 2020 at 5:50 PM
Good morning,
Can you upload the receipt of the repair that was performed?
Yes, it could fail within a year depending on the type of driving you to do every day.
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Dec 27, 2020 at 6:03 PM
GABBYGILBO
  • 55 POSTS
Attached is receipt.
Dec 28, 2020 at 3:21 AM
Okay, looks like they covered everything when they did the job.
What warranty did they give you with the repair?
Did you return for a follow up with them on the issue?
Dec 28, 2020 at 5:04 AM
GABBYGILBO
  • 55 POSTS
Firestones warranty has expired.
This should not be happening if in fact the repairs were done correctly. I just don't understand.
Where do I go from here?
What's your opinion at this point?
Deductive reasoning where should I start? No lose of fluid. No leaks. No noise. No smells. No vibrations. No indications whatsoever. Only that the clutch went straight to the floor. I can actually get her into first gear with a little effort and she'll jump forward.
Whatever advice you can give me would be greatly appreciated
Could it be as simple as air in the lines.
Note, car listed above is a 5 speed manual baseline.
Dec 31, 2020 at 12:51 PM
STEVE W.
  • 15,420 POSTS
It could be that one of the new parts failed, it happens, and unfortunately it seems to happen more now than in the past. Do you feel any resistance at all when you step on the pedal? What happens if you pump the clutch pedal a few times? From your description it could be air but it sounds more like something internal to the system failed, you could try bleeding it again and see if it helps.
Jan 1, 2021 at 10:06 PM
GABBYGILBO
  • 55 POSTS
There's no resistance in the pedal. When we begin bleeding there was some resistance then at one point it went straight to the floor again. The bleeder valve it's the fluid is not coming out like it should be at all at some points most of the time and then other times it's just spitting like a little spit spit spit spit that's it. The fluid level in the reservoir does not change by any significant amount.
At this point I went ahead and I'm going to purchase the master cylinder to the slave for $155.00 from AutoZone it comes with the actual rubber tubing and metal. I'm unsure but when I take it off I'm going to blow through it see if they're possibly maybe something stuck in the old one. I'll let you know about that. If not jimmy Christmas what do I do next? open up the transmission housing and maybe it's the drop bearing or something. I not sure at this point. thank you for your help. God bless you thank you very much.
Jan 2, 2021 at 4:30 PM
GABBYGILBO
  • 55 POSTS
What's baffling the most is this why would this occur twice. Same issue clutch pedal just goes to the floor no forewarning no smell no feeling no lots of fluids no leaking nothing at all. May 2019 and again December 2020.
May 2019 the master the slave all the lines the clutch kit was all replaced supposedly that's what I paid for anyway.
What would cause us to occur again?
Jan 2, 2021 at 4:33 PM
Okay, the quality of the parts could be an issue. A lot of times, aftermarket parts are cheaper than OEM but do not last as long as the original equipment.
I could not read the invoice for the type or manufacturer of the master and slave.
Bleeding
1. Attach a clear line to the bleed screw with the loose end submerged in a small container of clutch fluid.
2. Actuate the clutch pedal 5 times at a normal speed by stroking it all the way to the pedal stop in both directions.
3. Actuate the clutch pedal quickly 10-15 times without bringing the pedal all the way up, 30-40 mm (1.18-1.51 inch) short of stop at pedal.
4. Repeat steps 2-3 5 times.
5. Hold the pedal at up stop and open the bleed screw.
6. Stroke the pedal to the floor normally and close the bleed screw.
7. Lift the pedal to up stop position.
8. Repeat steps 5-7 3 times.
Notice: Refer to Fastener Notice in Cautions and Notices.
9. Tighten the bleed screw.
Tighten the screw to 7 Nm (62 inch lbs.).
10. Remove the bleed line from the bleed screw.
Clutch Master Cylinder Replacement
Removal Procedure
1. Clean the clutch fluid reservoir cap and area around the cap.
2. Remove the clutch fluid reservoir cap and remove enough brake fluid to clear a passage to the clutch master cylinder.
3. Remove the clutch pedal retainer.
4. Remove the clutch master cylinder pushrod from the clutch pedal assembly, 1st design.
5. Remove the clutch master cylinder pushrod from the clutch pedal assembly, 2nd design.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in Cautions and Notices.
6. Place a shop towel under the clutch master cylinder in order to catch any fluid loss.
7. Using a pick tool on the strut tower side, disconnect the clutch line from clutch master cylinder.
8. Cap the reservoir and hydraulic lines in order to prevent fluid loss and contamination.
Important: Do not damage the pushrod boot when sliding it through the front of the dash.
9. Remove the clutch master cylinder mounting nuts and slide the clutch fluid reservoir up and out.
Jan 2, 2021 at 6:44 PM
STEVE W.
  • 15,420 POSTS
With no fluid coming out of the bleeder I would say the master cylinder is the issue. With it full of fluid you should get a good shot of fluid out of the bleeder on every pump of the pedal. It sounds like the internal cup seal on the piston has failed or is bypassing fluid. The receipt you posted showed they replaced the parts, however if they used rebuilt parts it's possible that they were not high quality rebuilds. There is usually some internal wear and corrosion inside the bore of the master cylinder and if the rebuilder doesn't either bore out and sleeve or at least bore it so the entire area is clean and smooth it only takes one time for the piston seal to go past that area and get damaged. The seals are highlighted in red in the image. If they are damaged in any way the clutch stops working correctly. I somewhat doubt the issue is the internal slave as they normally leak when they fail.
There is a TSB on the clutch bleeding for your vehicle if the pedal isn't acting correctly. It involves using a handheld vacuum pump to pull any air out of the system, It might help.
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 01-07-31-002A (Section 07 - Transmission/Transaxle). This bulletin is being issued to inform dealers of an improved procedure to aid in the ease of bleeding the clutch hydraulic system for the above listed vehicles. This procedure can be used anytime air is introduced into the hydraulic system. Following this procedure may also reduce the number of unnecessary parts replaced for low clutch pedal reserve and high shift effort.
Verify that all the lines and fittings are dry and secure.
Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
Remove the reservoir cap.
Fill the reservoir to the proper level with the required fluid.
Attach the J 43485 (Adapter) to the J 35555 (Mity Vac), or equivalent.
Brake fluid will deteriorate the rubber on J 43485. Use a clean shop cloth to wipe away the fluid after each use.
Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter.
Refill the reservoir to the proper level.
If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
Pump the clutch pedal until firm.
Add additional fluid if needed.
Test drive vehicle to ensure proper operation.
The J35555 is a standard hand vacuum pump, There are a few types out there. I prefer the metal versions but most of them will work just fine. The special adapter J 43485 is nothing real special, just a tapered rubber cone with a hole in the center to allow for a seal on the top of the master cylinder. A simple cheaper version is a common sink stopper with a small piece of tubing glued into it. Just like the expensive ones brake fluid will damage it, but the easy solution is to use it, then rinse it off with water and dry it.
I would try that bleeding method first. Unfortunately with the state of parts these days it's becoming a big gamble as to what you get in new and remanufactured parts. I have taken "brand new" parts and found them defective right out of the box, it's very possible that is also part of the reason it failed so soon. It's also possible that given that some parts of the system are plastic, that one of the seals or clips or even that part itself is letting in air and you no longer have a working clutch.
When this occurred did it go from, clutch worked fine one day and the next it failed or has it been getting worse over a length of time? A sudden failure would point more to a seal or part failure while a slower failure would point more toward air entering through a small leak in an O-ring or a loose clip not holding the parts together tightly.
Jan 2, 2021 at 7:27 PM
GABBYGILBO
  • 55 POSTS
First off I have to say thank you very much for you being here for me.
I have replaced the master cylinder.
I bleed the system according to instructions provided by multiple sources.
I have an issue.
The push rod ie, the pedal will only go approximately 2 in down and it's really hard it just that's it and I cannot get in a gear of course now I can't even start it because it won't go all the way down to hit the button you understand what I mean start the car.
My question is, what is it that is stopping it seems like there's too much pressure in my system now?
What did I do wrong?
Help please.
Jan 5, 2021 at 7:34 AM
GABBYGILBO
  • 55 POSTS
Could it be that when I installed the value piece that it's into the housing that goes to the slave could I have maybe maybe not connected it correctly so that they didn't get into each other's right? I don't know how to explain it it has the valve that you stick into the housing and then there's a little pin from the slave that's inside the housing that sticks into that could it I don't think it's that but because that would stop the pressure of the fluid correct the fluid wouldn't be coming out correctly is that correct? I am so confused I'm so confused at this point.
Jan 5, 2021 at 7:35 AM
GABBYGILBO
  • 55 POSTS
FYI To ASEMaster6371 my Vue had this issue back in 2018. Everything was replaced at the master the slave the clutch kit. Now my vehicle is doing the same thing it just went to the floor the clutch just went to the floor no indication whatsoever.
Jan 5, 2021 at 7:38 AM
If you remove the slave cylinder, does the pedal travel further?
It does not matter how old the parts are. Even new ones fail early.
Jan 5, 2021 at 7:47 AM
STEVE W.
  • 15,420 POSTS
As Roy asked, it sounds like the slave cylinder may be fully extended and cannot travel any farther. If that is the issue then it would stop the pedal from moving. It would also point to a possible failure in the pressure plate as the root cause of the problem. I would start by opening the bleeder and verifying that you have full travel in the master cylinder by releasing the fluid. If the master now moves and you can push the clutch down then the actuator is either stuck in place or the pressure plate has an issue. I would then use a small camera to look inside the clutch area on the transmission and see what the slave and pressure plate are doing. If the pressure plate has failed or something has jammed the slave cylinder it should be easy to see. You can get cameras like that which plug into a phone or tablet and let you go into the case and look around. I seem to recall there is a notch on the case that would give you access to the clutch area.
Jan 5, 2021 at 11:45 AM
GABBYGILBO
  • 55 POSTS
All of you thank you for your help. This is what I found out. GMC discontinued this part. Unable to purchase through the dealership.
I purchased a master cylinder from O'Reilly's but it was at the wrong angle. I'm unsure what you call that little round enclosed metal piece that goes to the metal line just outside of your master cylinder that comes through your firewall... at any rate what happened was it was at the wrong angle, t would not clear my brake lines nor go up against the wheel well firewall where it is to be. So I took it back to O'Reilly's what happened was their employee and I together torqued to put in correct position for insulation. Make sure you take your old one with you so you have the right angle! This was not easy at all it was torqued on by the manufacturer. To get to the concussion I went ahead and I installed this master cylinder. She's running she's running she's running after little bumps and bruises and scratches on I got to say the worst part about this job was getting the battery and the fuses all those lines out of the way so that I was able to put the line up against the wall. There's a lot of maneuvering to do and these pieces are just plastic in their very easily broken. another thing is: Do not lose the clip that goes on the valve that goes into the transmission housing. You will be unable to find it anywhere trust me I checked. Similar ones don't clip as hard if that makes sense, thank you guys, thank you, thank you, thank you! I hope everybody learns from this because I got bumps and bruises and scratches from doing this and I appreciate you guys being there for me God bless us all.
Jan 13, 2021 at 9:06 PM
You are welcome.
We are always glad to help.
Jan 13, 2021 at 9:10 PM
GABBYGILBO
  • 55 POSTS
Being able to correspond with someone that does not have an ulterior motive is priceless.
Thanks for just being there.
Jan 14, 2021 at 10:28 AM
Anytime.
Jan 14, 2021 at 10:51 AM
GABBYGILBO
  • 55 POSTS
Hello once again I'm going to ask you for your assistance. I would like to have a part number cross referenced. As you may be aware I replaced my clutch master cylinder. The following pictures of old clutch master cylinder
inside the firewall on the shaft has part PA66-GF35.
On the connector of shaft to clutch pedal part number is PA6-GF25.
On the bleeder valve it has part number pa66 - gf35 from the line into the slave actually the transmission housing there's part number 8060.01.
I would like you to please cross reference these numbers and inform me of the information that you obtain.
Jan 17, 2021 at 3:00 AM
What is the part number of the replacement master cylinder?
The numbers you gave me are casting numbers for the parts.
Jan 17, 2021 at 3:08 AM
GABBYGILBO
  • 55 POSTS
Thank you for your response please I ask of you to let subside that issue for a moment. I am trying to get my vehicle safety ready to drive from California back home to Ohio. I have another issue I'm trying to fix my horn a while back when it beeps on the horn it got stuck so I pulled off the freeway and I pulled out the fuse. I bought the books I went online I am unable to figure out how to get to my horn okay there's four bolts in the back excuse me not bolts screws and the back of my steering wheel in addition to that I have that plastic this plastic cover when I try to pull it off it's really hurting my fingers I don't know how to pop it off can you help me with this issue to fix my horn because it's stuck if I put my fuse back in it'll stay on please I'm trying to get home before the weather won't permit me to do so, or covid again and again.
Gabrielle.
thank you in advance for your help in this matter you are much appreciated.
Jan 24, 2021 at 3:53 PM
Okay. we can only deal with one issue per question.
Please start a new question and I would be happy to help you with the horn issue.
Jan 24, 2021 at 9:09 PM
GABBYGILBO
  • 55 POSTS
Okay, thank you. New question.
I have researched on web and book for how to disassemble the steering wheel to have access to my horn. I'm positive it's inside because when I hit it one day on the freeway it's stuck so I had to take out the fuse out of the engine compartment. The ones explaining to me if the in fact the horn is attached to the airbag that's in there and how to pop off the steering so that I could get to it the horn that is. thank you. I hope I explained it correctly.
Jan 27, 2021 at 6:19 PM
You need to go all the way back to the beginning and start the new question. I will be happy to help once the new thread is started.
Jan 27, 2021 at 7:32 PM
