Watched your video on clutch replacement. Very good, well done. How difficult is the re-installation of transmission? Will the transmission input shaft properly engage with clutch disk and pilot bearing without putting force on the pressure plate? Does the hydraulic release bearing need to be connected and activated? May I call and speak with you?
Thanks
Thanks
May 4, 2020 at 1:12 AM
