Clutch replacement
130,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
LORI VOORHIES
If you are just replacing pressure plate and throw out bearing do you still need to remove master cylinder and slave cylinder?
Sep 25, 2019 at 12:08 PM
  • 110,246 POSTS
Welcome to 2CarPros.
The slave is bolted to the transmission, so it will need disconnected (at a minimum) so you can move the transmission back to replace the parts. I don't see why the clutch MC would need removed.
If you need directions on anything, let me know.
Sep 25, 2019 at 12:38 PM
LORI VOORHIES
Got too many instructions from places an people. I am going to have whole car tore apart. yes, need full instructions on how to and what to remove an what tools. Thank you.
Sep 26, 2019 at 9:29 AM (Merged)
