Clutch repair now the car idling very rough?
2003 MITSUBISHI ECLIPSE
200,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
DANIELCORNISH
Had a new clutch kit and flywheel put in and now the car idles very rough with a rumble. could it be not lined up right or not torqued correctly?
Oct 11, 2022 at 9:48 AM
  • 110,244 POSTS
Anything is possible. However, since the work requires a lot of disassembly, there is a good chance they left an engine vacuum hose disconnected or a sensor unplugged.
Do me a favor, first check to see if there are any disconnected or damaged vacuum hoses.
Here is a link that explains how it's done:
Let me know what you find. Also, let me know if the check engine light stays on when the engine is running. Also, does the clutch seem to function properly?
Oct 11, 2022 at 1:40 PM
