Clutch repair there is no clutch grab what so ever
151,712 MILES • 4.0L • 6 CYL • 2WD • MANUAL
JAY MARGENTINA
The person I purchased this car from said that he had the clutch replaced two years ago by "a friend". After six months of driving the clutch went out and he parked it. I got it running and found that there is no clutch grab what so ever. When I put it in "gear" and release the clutch pedal, the idle rpms do not even drop. Then I shifted through every gear without using the pedal and did not feel or hear any grinding.
Jan 4, 2017 at 3:03 AM
HMAC300
  • 48,601 POSTS
it sounds like a clutch bad but put in gear and start see if it moves if it does it is a hydraulic issue be careful though with nothing around you.
Jan 4, 2017 at 4:08 AM
JAY MARGENTINA
It has a safety switch so I cannot start it without pressing down on the clutch pedal.
Jan 4, 2017 at 4:30 AM
  • 31,937 POSTS
If you still have good pedal pressure i would say the clutch has l failed. it may have lost all the linings or blown out the hub. pull the gearbox and start with inspecting the clutch.
Jan 4, 2017 at 6:42 AM
JAY MARGENTINA
Thanks. I appreciate the feedback.
Jan 4, 2017 at 1:02 PM
  • 55,658 POSTS
Please let us know happens so it will help others.
Best, Ken
Jan 9, 2017 at 4:46 AM
