Clutch not working after replacing starter
200,000 MILES • 5.7L • V8 • 4WD • MANUAL
ANGELAKNOTTS64
Took slave cylinder off to replace the starter and when I put it back on I had no clutch. I've tried bleeding the line and it's full of fluid but still have no clutch.
Dec 31, 2019 at 10:25 AM
When you say the clutch is not working, what exactly is happening? Does the pedal not return or what exactly is the issue?
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Jan 1, 2020 at 9:02 AM
