Clutch Problems
97,000 MILES • 1.6L • 2WD • MANUAL
KLB992
My clutch pedal is not holding pressure. I am unable to put the car in gear. The pedal goes straight to the floor. I have tried to pump the clutch and it will not build pressure at all.
Jan 6, 2018 at 11:32 AM
KHLOW2008
  • 41,812 POSTS
Usually when clutch hydraulic system is not holding pressure, the clutch master cylinder is bad. Internally pressure is leaking between the seals. You would need to have it replaced.
Jan 6, 2018 at 1:48 PM
KLB992
Would I need to get anything else other then the master cylinder?
Jan 6, 2018 at 8:44 PM
KHLOW2008
  • 41,812 POSTS
When replacing the master, it is good the have the slave cylinder serviced or replaced as well. Replacing one could mean the next thing to give way would be the slave cylinder and compared to the master cylinder, it is not as expensive.
Jan 7, 2018 at 5:57 PM
