clutch problems
114,000 MILES • 3.2L • V6 • RWD • MANUAL
MARCOCARV
car is running fine then you step on clutch and it goes to floor and will not return. After several minutes, it comes back up and may run fine for several hours or several days. Had master cylinder replaced and transmission rebuilt, to no avail.
Mar 15, 2016 at 5:40 AM
HMAC300
  • 48,601 POSTS
this can be a couple of things, broken springs on pressure plate, worn bushing on release arm. hose going to slave collapsing or a slave not moving well
Mar 15, 2016 at 9:38 AM
