I push the clutch pedal about halfway down it makes a grinding
170,000 MILES • 3.7L • V6 • 2WD • MANUAL
C89ROBINSON
When I push the clutch pedal about halfway down it makes a grinding or rubbing sound it will not shift.
Jul 17, 2019 at 3:47 AM
Good afternoon,
Sounds like the throw-out bearing in the clutch has failed.
You will need to remove the transmission and inspect the bearing, pressure plate and disc.
https://www.2carpros.com/articles/how-to-replace-a-clutch
May 1, 2021 at 11:26 AM
C89ROBINSON
Thank you. I was thinking the exact same thing but wasn't sure if i was right. I really appreciate your help.
You are welcome.
Always glad to help.
I got an email that you responded but nothing came through.
Can you resend?
