Anytime I shift the transmission into gear and release the clutch, it grinds, what could it be?
125,000 MILES • 4 CYL • MANUAL
ALLY492
I was driving home and I shifted into first gear, turned right and then it just started this grinding sound and stopped going forward.
Oct 10, 2022 at 2:30 AM
  • 55,721 POSTS
So, what happens is the CV axle has fallen out of the transmission, I would raise the front of the car and with a flashlight check to see if the CV axles are fully seated into the transmission differential.
Here is a guide that will help you raise the car up:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
and
https://www.2carpros.com/articles/replace-cv-axle
This video can help as well, it is a similar car, but you can see how to seat the axle.
https://youtu.be/zxEwcxS3JDk
Let us know what happens and please upload pictures or videos of the problem.
Oct 10, 2022 at 8:33 AM
