Clutch problem
156,000 MILES • 2.3L • 4 CYL
TEEBIRD MECHANICS
After changing clutch truck stays in gear in neutral no reverse.
Mar 4, 2018 at 4:25 AM
Good afternoon.
Does the shifter move around in it neutral gate?
does the clutch pedal feel good? Will it release the clutch?
Can you shift gears with the engine off?
Mar 4, 2018 at 5:02 AM
TEEBIRD MECHANICS
Yes to all those questions.
Mar 4, 2018 at 5:07 AM
WRENCHTECH
  • 20,760 POSTS
It sounds like you did not line up the shifter correctly when you installed it. It has to be in neutral (all slots aligned straight across) when the stick is installed.
Mar 4, 2018 at 5:09 AM
Yes, as Wrenchtech said, the shifter is out of sync with the shift rails.
remove the shifter again and use a screwdriver to align the three rails so the slots are all lined up in the middle. then install the shifter, bolt it down and then try it again.
Mar 4, 2018 at 5:14 AM
TEEBIRD MECHANICS
Okay thanks. I will let you know what happens.
Mar 4, 2018 at 5:17 AM
You are welcome, we will be here.
Mar 4, 2018 at 5:19 AM
TEEBIRD MECHANICS
It fixed it for a minute does this mean I need a shifter kit?
Mar 4, 2018 at 7:09 AM
If it came out again then you may have a shifter rail issue internally. the shift just moves back and forth, up and down.
Mar 4, 2018 at 7:18 AM
TEEBIRD MECHANICS
Thanks for all your help.
Mar 4, 2018 at 7:20 AM
you are welcome.
Mar 4, 2018 at 10:41 AM
