After changing clutch truck stays in gear in neutral no reverse.
Sunday, March 4th, 2018 AT 12:25 PM
MECHANIC
Good afternoon.
Does the shifter move around in it neutral gate?
Does the clutch pedal feel good? Will it release the clutch?
Can you shift gears with the engine off?
SPONSORED LINKS
Sunday, March 4th, 2018 AT 1:02 PM
TEEBIRD MECHANICS
MEMBER
Yes to all those questions.
Sunday, March 4th, 2018 AT 1:07 PM
WRENCHTECH
MECHANIC
It sounds like you did not line up the shifter correctly when you installed it. It has to be in neutral (all slots aligned straight across) when the stick is installed.
Sunday, March 4th, 2018 AT 1:09 PM
MECHANIC
Yes, as Wrenchtech said, the shifter is out of sync with the shift rails.
Remove the shifter again and use a screwdriver to align the three rails so the slots are all lined up in the middle. Then install the shifter, bolt it down and then try it again.
Sunday, March 4th, 2018 AT 1:14 PM
TEEBIRD MECHANICS
MEMBER
Okay thanks. I will let you know what happens.
SPONSORED LINKS
Sunday, March 4th, 2018 AT 1:17 PM
MECHANIC
You are welcome, we will be here.
Sunday, March 4th, 2018 AT 1:19 PM
TEEBIRD MECHANICS
MEMBER
It fixed it for a minute does this mean I need a shifter kit?
Sunday, March 4th, 2018 AT 3:09 PM
MECHANIC
If it came out again then you may have a shifter rail issue internally. The shift just moves back and forth, up and down.
