Clutch problem
10,000 MILES • 1.2L • V6 • 4WD • MANUAL
HJAYE
We have a problem with the clutch. First it started making noise when the pedal is push down and now no noise is coming out because we only drive in gear but still has problem with shifting the gear. Can you help please?
Sep 8, 2018 at 11:43 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
The noise you hear when you depress the clutch is called the Throw Out Bearing. Unfortunately to replace that the whole transmission has to come out to replace. It is my opinion since the transmission will have to come out it would be cost effective to replace the clutch assembly. I have attached a few tutorials showing what is involved. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/throw-out-bearing-replacement
Sep 8, 2018 at 2:47 PM
