Clutch problem
170,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
EBABIY
I have the car listed above with weird issue. Pressing pedal to the floor does not disengage the clutch which will not allow to shift into gear. when in the process of bleeding the system the clutch pedal will go all the way to the floor, full stroke when bleeding is finished it is back to only going half way to floor and will not disengage clutch.
Dec 16, 2018 at 4:57 AM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com.
Based on your description, it sounds like either the slave cylinder is bad (which I doubt in this case) or something has broken in the system which isn't allowing the slave to disengage the clutch. Chances are the throw out bearing is damaged (cracked). If you are able to full press the pedal when bleeding, then that is my first suspect.
Take a look at this listed issue and repair. This was listed as a repair to a similar problem in Alldata's records.
____________________________________________________________________________
Crack (open) the line at the slave cylinder, if the pedal moves freely, then you've found your issue.
TECH-ASSIST
01/27/2016 | 10:08:31
1 Repair(s) Available
Verified Repair(1)
TECH-ASSIST
01/27/2016 | 10:11:31
Replaced the faulty clutch slave cylinder/throw-out bearing assembly.
Let me know if this helps.
Dec 16, 2018 at 12:14 PM
