Clutch problem
1,275,000 MILES • 2.0L • 2WD • MANUAL
MARTYG85
Hi, my clutch was sticking to the floor and I had to pull it back out with my foot and it was hard to put it into gear and then it would not go into gear. so I had to stop the car and start it in gear but it would not move . all it is doing is making a rattling noise when idle but when you press the clutch in the noise goes away. what would the problem be?
Dec 10, 2017 at 6:54 AM
  • 110,248 POSTS
Chances are the slave cylinder or clutch master cylinder is empty or bad. Follow these directions:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Dec 11, 2017 at 9:48 AM
