Clutch pressure control (linear) solenoid valve A failure
100,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JAMES WILLIAMSON4
I have an engine code P1768 which I have purchased new clutch solenoids A and B as well have tested which both are working fine. I have tried a reset which did not clear the code. There is a very large clunk when shifting from park to reverse or drive and when in drive the rpm's are high but the vehicle moves very slow before eventually gaining speed.
Jul 10, 2018 at 6:45 AM
  • 110,248 POSTS
This is an interesting one. What I have done is attach a picture with the test procedure from mitchel, Prodemand. Take a look through it and let me know if it helps. Sorry I had to put it in a picture. I had no choice.
Jul 12, 2018 at 12:54 PM
