There's plenty of fluid in the slave cylinder and the slave cylinder was replaced maybe 50,000 miles ago could this be it?
Jan 1, 2023 at 9:32 AM
✓Experienced Mechanic
There is an adjustment at the pedal for the master cylinder to help take up the slack in the clutch system. Loosen the jam-nut to adjust the threaded rod outward which will take up the slack. Check out the images (below). Please let us know what happens.
