Clutch pedal reattachment to the pedal assembly
140,000 MILES • 6 CYL • 2WD • MANUAL
BOB%
  • 70 POSTS
When i got my car the clutch return spring on the pedal assembly was broken. therefore, after i put new bronze bushings into the assembly,i have no idea how much pressure has to be put on the clutch return spring when i re-attach the clutch pedal to the rod and put the pin through it.should the pin be put into the rod vertically,or horizontally?there has to be enough spring pressure from the spring to draw back the cable.please let me know what to do.thank you Robert Mason.
Aug 20, 2020 at 4:54 AM
4DRTOM
  • 467 POSTS
You only need enough to pull the pedal back to position as long as its tight. The more tension the quicker the return. Is this bushing not a Porsche part?
Tom
Aug 20, 2020 at 3:49 PM
BOB%
  • 70 POSTS
I replaced the nylon bushing with a bronze bushing (a Porsche part). my question is, how much tension should be put on the return spring(it's attached to the same rod that the clutch pedal attaches to)in order for me to attach the pedal back on the rod and put the pin in to hold the pedal on the rod?does the pin go in vertical,or horizontal?
Aug 20, 2020 at 11:39 PM
  • 55,561 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Aug 21, 2020 at 4:41 AM
BOB%
  • 70 POSTS
Ken, I'm trying something and I'll let you know if it works. P.S. I don't know how to download videos etc.Take care,BOB.
Aug 21, 2020 at 7:30 AM
4DRTOM
  • 467 POSTS
Hello Bob,
If you use your phone to take a video,when it's open and your looking at the recording of it there should be a place to share it. You could share it to your email then get the email on your regular computer and save it from there to the desktop. Then when your on 2CarPros and you click upload an image open the file from your desktop.
Tom
Aug 21, 2020 at 1:01 PM
BOB%
  • 70 POSTS
Tom,
I'll try that if my attempt fails.I'll let you know if my solution works.Either way,thank you for your help,BOB.
Aug 21, 2020 at 2:11 PM
4DRTOM
  • 467 POSTS
Hi Bob,
Sounds good, I will keep my eye out for you.
Tom
Aug 22, 2020 at 1:17 AM
