Clutch pedal removal
IAMRACERX
  • 2009 CHEVROLET COBALT
  • 2.2L
  • 4 CYL
  • MANUAL
  • 50,000 MILES
How do I remove the clutch pedal? I have taken out the 5 nuts that seem to hold it in. Disconnected the cable. Disconnected the hydraulic piston. Still it will not come out. Please advise.
Saturday, August 9th, 2014 AT 12:44 AM
HMAC300
  • 48,601 POSTS
Ere I a pic but we have no instructions on removing it. Here is pic but it may be hanging up on master for clutch and you may have to remove underhood electrical center.
Saturday, August 9th, 2014 AT 6:20 AM
GUYINKNAPP
  • 2007 CHEVROLET COBALT
  • 2.2L
  • 4 CYL
  • MANUAL
  • 111,111 MILES
I broke my clutch pedal arm and got a new clutch pedal assembly from the junk yard. I asked if they had tips to get it out he said he just keep taking parts off until he could get at it. I have the two bolt and master cylinder rod off. But the bracket hangs up on the I think power steering pump and bracket. How much needs to come off to get the assembly in and out?
Monday, March 1st, 2021 AT 12:08 PM (Merged)
STEVE W.
  • 15,397 POSTS
Shouldn't need to remove much. Basically you disconnect the master cylinder rod. The two nuts come off and the wiring and the pedal bracket should drop down and come out.
If the steering assist motor is in the way it is held on with just the two bolts.
