Clutch pedal
267,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
GREG BISHOP
Hi, I read your post about how you used the 3/8 copper pipe and some PVC and things to fix the clutch pedal where it broke up in the bracket. mine broke as well. do you have any more pictures and can you tell me about how you did it? all I have is the spring and the original little white plastic piece.
Thanks,
Greg
Feb 11, 2018 at 10:27 AM
  • 31,937 POSTS
If the pedal box has failed you may be better off getting a replacement unit from a wrecker. i have not seen the post you are talking about, but the pedal box has to be removed to do any work on it, so replacing would be far quicker, and the repair as you said you have seen may not work on your problem.
Feb 12, 2018 at 8:34 PM
